| I finished replacing my High pressure hose, and replaced the copper washers, and most of the ps leak is gone. There seems to be one leak that I can't tell where it is coming from at all. All the hoses on the Hicas device in the front passenger side of the engine bay are dry up top. It seems like a hose from the pump is leaking, but I can't see which one. In addition, you shouldn't start the car to see the leaks around the pump when you have the intercooler hoses removed. How do most people check for leaks? I have read all the ps leak posts and pretty much people say: 1. Tighten all bolts and hoses (but how? there's no space in there...) 2. Use Lucas to stop leaks.
